Hello,
I'm using Adobe Premiere Pro CS5 to edit my video but i don't know how to export to avi file with the same quality...?!
In the previous version Premiere Pro CS3 i can export the video into avi with the same quality using Windows Media Video 9 Codec but in Premiere Pro CS5 i don't know how to do it...!!
Video Info:
Code:General Complete name : Thefirst.avi Format : AVI Format/Info : Audio Video Interleave File size : 401 MiB Duration : 24mn 6s Overall bit rate : 2 329 Kbps Writing application : VirtualDubMod 1.5.10.2 (build 2540/release) Writing library : VirtualDubMod build 2540/release Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 24mn 6s Bit rate : 2 125 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.231 Stream size : 366 MiB (91%) Writing library : XviD 1.2.1 (UTC 2008-12-04) Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 2000 Duration : 24mn 6s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 33.1 MiB (8%) Alignment : Split accross interleaves Interleave, duration : 33 ms (1.00 video frame) Interleave, preload duration : 500 ms
Best Regards,
SB4
Results 1 to 1 of 1
Export high quality videos from Premiere cs4 on mac
By hasanali00 in forum Video ConversionReplies: 2Last Post: 5th Mar 2010, 15:41 -
Premiere Export Always Blurry
By helloitsdan in forum EditingReplies: 2Last Post: 23rd Jan 2010, 08:40 -
Premiere Elements 3 Export to DV-AVI or m4v file?
By bowmah in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2008, 18:12 -
Should I export from Premiere using DV or HuffyUV?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Sep 2007, 01:28 -
Sequence export - Premiere 2.0
By iSerce in forum EditingReplies: 0Last Post: 28th Jun 2007, 06:28
